Design >> Analog Design >> Operational Amplifier Design
https://designers-guide.org/forum/YaBB.pl?num=1650038214
Message started by Kenny Lu on Apr 15th, 2022, 8:56am
Title: Operational Amplifier Design
Post by Kenny Lu on Apr 15th, 2022, 8:56am
Dear all,
I have started to learn to design a two-stage operational amplifier recently and have got some questions regarding the design flow and simulation methods.
Simulation Method:
1. How should we set up the opamp so that we can simulate and design its open-loop response correctly?
Design Flow:
2. In designing an operational amplifier, should we focus on designing the opamp's open-loop response first before designing its loop gain response (As we know it will be used in a feedback configuration in the end)?  Can someone please show me the standard design flow for a two-stage operational amplifier?
Thank you in advance
Kenny Lu
