achim.graupner
Dear all,
I spent part of the day to write an ocean script for verifying the impact of trimming. It does the following: 1. it does a simulation at nominal operating conditions for a random realization of the circuit's device parameters 2. it computes a trimmung value 3. it repeats the above simulation for the *same* random realization of the circuit's device parameters to check whether the trimming was sucessful 4. it repeats the simulation for different operating condition, again for the *same* random realization of the circuit's device parameters
The code could surely be optimized ... The example is an amplifier (which later will be part of a trimmed signal path) Regards, achim
