Jul 19th, 2024, 10:15pm
Warning which cannot be explained. (Read 1944 times)
shuting84
Jan 23rd, 2006, 5:19pm
i am using IBM 0.13 um PDK and hspice
 **warning**  in element= 42:cwiredb          defined in subckt nfet
 capacitance =    0.00     <= 0 farad, please verify it.
Warning: Pd = 2.75e-07 is less than W.
Model:   42:nfet
W = 3.2e-07, L = 1.2e-07
I keep getting such warnings on the elements of my subcircuit when I run my simulations. I checked my circuit and verified that PD >W.
I am assuming cwiredb refers to capacitance between drain and body. the body of my nfet is connected to ground, and drain is the output. they are totally not connected together. i have no idea why capacitance would turn out to be 0.
i am suspecting that while the model is being formed, some errors are occuring, and the simulator is trying to create a model which is different from what I am trying to create.
Re: Warning which cannot be explained.
Reply #1 - Jan 25th, 2006, 10:21am
Can you find the subckt definition?  Don't post any proprietary model parameters here.  Presumably, the subckt has parameters W,L,AD,PD, etc.;
are they passed directly to the actual MOS element inside the subckt?  I'm guessing not, and maybe the equations are confused.
I once found this in a different foundry's subckt for well proximity:
.param xw='1.5e-8' wint='6e-9' weff='l+xw-2*wint'
Note that weff is computed from l instead of w.
