Aug 17th, 2024, 12:23am
Inductor in PA design (Read 6403 times)
jxbvt
Feb 26th, 2006, 12:01pm
hi all....can some one explain this sentence to me.i have a fair idea but i was wondering exactly what is meant by:
"Output and load inductors will likely be off-chip due to high level of currents required". i know inductors are lossy and have low Q and that's why it's hard to implement them on chip but isn't it regardless of high levels of current or not. guess what i want to know is how current level prevents implementing inductors on chip. thanx
jb
ACWWong
Oxford, UK
Re: Inductor in PA design
Reply #1 - Feb 27th, 2006, 4:13am
metalization in silicon processes are typically ALuminum (although now copper is fairly common).
what limits the high current is electron migration... ie. too much current causes the metal to heat and eventually effectly distort/melt. to over come this one must make tracks wide or stacked to carry the current densities in high power circuits. When one considers that current of about 1mA/um width are typical, you can see even with thick top metal its becomes impossible/very difficult to make inductors take 100's mA and still meet the electron migration rules over tempertaure.
jxbvt
Reply #2 - Feb 27th, 2006, 10:07am
Thanks for the reply...makes sense.  Practically, yes electromigration issues are very important and place a limit on conducting current but theoritically isn't migration issue a reliability issue?  Meaning, let's say a circuit will be used once once (lol) then electromigration won't be an issue because the degradation is over time, right?
jb
milkdragon
RF idiot
Reply #3 - Feb 27th, 2006, 2:44pm
Electromigration is a physical issue.  Once your current limit exceeds, the metal will melt.  It is not something like it would degrade over time.  There is another issue called mobility degradation, which is a function of time instead for PA design, this is especially true for CMOS process
View Profile milkdragon   IP Logged
Reply #4 - Feb 28th, 2006, 7:36am
A useful paper I just found on Electromigration - http://www.cadence.com/whitepapers/4095_Electromigration_WP.pdf
ACWWong
Oxford, UK
Reply #5 - Feb 28th, 2006, 7:57am
the electron migration effect is usually gradual effect over time, and of course depends on how much over the current density limits given by the foundry and the temperature (real chip temperature, not ambient and for a PA that'll be pretty hot!) as to how fast it degrades.
Of course if you measure something once and for a short period of time, you'll be ok if you are just outside the reliablity quoted by the foundry. But gradually the track resistances will increase, so over time your measurements will get worse. eventually you could get tracks that dislocate or even adjacent tracks could short.
I think the book by Hastings "Art of Analog Layout" covers the subject quite well.
jxbvt wrote on Feb 27th, 2006, 10:07am:
jb
totowo
SH, PRC
Reply #6 - Aug 31st, 2006, 7:12pm
The current limit of inductor is quite right.  But the answer to jxbvt's primary puzzle, i think, is not this.
The inductor of output match is offchip because of its High Q.
For example, if the on-chip inductor has a 3dB loss, that means half of the power is wasted.
at input port, the input power is, e.g. 0dBm=1 mW, so the loss is only 0.5mW. It's receivability.
while at output port, the output power is, e.g. 20dBm=100mW, so the loss on inductor is 50mW!!!
It degrades the efficiency too much! Although the loss is 3dB too.
Let's think in another way, the parasitic series res is, e.g. 100Ohm, when the current on inductor is 1mA, the loss is 0.1mW; while when the current on ind is 100mA, the loss is 1W!!!
In fact , the current limit of inductor is not the primary reason, for we can parallel several inductor to share the big current.
View Profile totowo totowo   IP Logged
Reply #7 - Sep 3rd, 2006, 1:30pm
In the RF PA world, in additiion to electromigration there are a few other issues also:
Q of inductors needed.
PAE of the RF PA. Lossy inductors in a PA can kill your PAE numbers and make the product not viable.
Especially true of a PA in a cell phone.
