Jul 16th, 2024, 1:55am
Two tone TEST to check intermodulation (Read 4773 times)
yagi
Jan 26th, 2007, 6:03am
Hello everyone,
     I am trying to do a intermodulation simulation for my system giving two sinusoidal frequencies at 20Mhz.   But I dont know what two input frequencies to feed into my system to get the output spectrum using DFT function in spectre calculator. I tried feeding 20 and 19Mhz signals and did a DFT with hamming window but the two tones in spectrum are spread into bins on both sides.
  Can anyone help me how to do this test and see the output spectrum with two singal tones and intermodulated tones.
  Yagi
Re: Two tone TEST to check intermodulation
Reply #1 - Jan 26th, 2007, 7:18am
I believe the spreading is caused by the use of the Hamming window. With sinusoidal signals you should not need to use a windowing function.
ACWWong
Oxford, UK
Reply #2 - Jan 26th, 2007, 7:55am
and you'll want to ensure the dft is over an interval that is a integer multiple of 1 us to get the right bin spacing for a 20MHz-19MHz = 1MHz....
Croaker
Reply #3 - Jan 28th, 2007, 12:37pm
Yup, if it helps, the points are spaced by fsampling/N where N is the number of points used in the FFT.
