There are two solutions - one is to run "amsLibCompile" in <instdir>/tools/dfII/bin. This will compile all the Verilog-A libraries in the DFII installation. This is a configuration step during installation, but you can run it afterwards. To do this though, you'd need write access to the library.
The other approach is to add:
ASSIGN ahdlLib TMP ./ahdlLib_tmp
into your cds.lib file. This tells it to use ahdlLib_tmp in the working dir as a writable temporary directory for derived data from the ahdlLib - and so ncvlog will be able to compile into that.
