rajdeep
Can anyone please send me a link of SKILL command manual? Is it available in the cadence installation directory? then please tell me the path.
I only could manage a reference manual for ocean script. It has a section of introduction to skill commands. But it only contains syntax and semantics of those skill commands which are useful for simulation purpose.
I want a whole set of documentation on skill language. Only the descriptions (syntax and semantics) of its inbuilt funtions will be of great help.
For the time being, I'm stuck with the function deNew. This I discovered from the log file.
The command I used in the ocean script is the following: deNew('(nil libName "rajdeep_VAmodels" cellName "new"))
It creates a cell with name new in the library rajdeep_VAmodels. The default view is schematic.
But if I want to do the same to create a VerilogA view of the same cell, I'm stuck. How would I specify the view?
I made a guess, and used the following command: deNew('(nil libName "rajdeep_VAmodels" cellName "new" viewName "veriloga"))
It worked. It created the veriloga directory under rajdeep_VAmodels/new/, but did not create the files under it. Files like veriloga.va, master.tag were not created.
I must be missing something. Don't know what. Please help!
Thanks, Rajdeep
