makelo
Hillsboro, OR
I want to improve the VerilogA file that I use to write data to a text file. The current version works but does not allow me to change the file name during execution of the program. I tried using the the STRCAT function to concatenate a two strings but that does not work.
Here is what I currently have that works.
`include "disciplines.vams" `include "constants.vams"
module sink_IQ(vi,vq); electrical vi,vq; parameter string file_name = "dat1_out.tbl"; parameter real T_step = 1e-9; integer file_ptr, hdrPrinted;
analog begin @( initial_step ) begin file_ptr=$fopen(file_name); end
@(timer(0,T_step)) begin $fwrite(file_ptr, "%e %e %e\n", $abstime, V(vi), V(vq)); end
@ (final_step) begin $fclose(file_ptr); end end endmodule
I would like to add a line like file_name = strcat(file_name,suffix); within the code to allow me to change the file name. Is there another way to do this?
Thanks, Makelo
