Jul 17th, 2024, 2:34pm
Issues with Virtuoso AMS (Read 2580 times)
leena2k6
Jul 14th, 2007, 12:53pm
I have recently started to develop AMS environment(Cadence Virtuoso AMS) at chip level.
The testbench components are System Verilog and the design is mixed verilog  + vhdl.
While running verilog -irun ...command, i see some issues in ncelab. The error is something like -
Hierarical component lookup failure testbench.top.......cfash0.ftop.IFLH
FYI, the same pattern runs fine when run without ams options i.e without giving -propspath option in the verilog run command.
Also the testbench is SV, top, cfash0 is verilog code, ftop is a vhdl code whereas IFLH is verilog.
The cflash0, ftop, IFLH are all digital blocks.
Any clues why do i see this issue?
Leena
Daniel Liu
Re: Issues with Virtuoso AMS
Reply #1 - Aug 7th, 2007, 2:41pm
Hi Leena,
My name is Daniel Liu, AMS PE from Cadence. I got forward for your issues. I have good news for you. Ramkumar has been working with us and we are sending his an ER with this fix.
Please check with him a little bit latter.
Daniel
