Jul 16th, 2024, 10:34am
LDO modeling (Read 5114 times)
chouba
tunisia
LDO modeling
Feb 27th, 2008, 2:24am
hello,
i m trying to model in vhdl-ams low drop-out voltage regulator,
i m searching for existing model, but i don’t find ...  ::)
in some one know some ams existing model, that's will be fine
View Profile chouba   IP Logged
safwatonline
Re: LDO modeling
Reply #1 - Jun 27th, 2009, 9:24am
chouba wrote on Feb 27th, 2008, 2:24am:
hello,
What are you trying to model?
a simple model can be made by a simple multiplication of the reference by a constant.
Peruzzi
Re: LDO modeling
Reply #2 - Jul 1st, 2009, 9:11pm
Chouba,
What do you need the LDO model for?  In your simulation testbench will the models of the load be drawing current from the LDO or are you just supplying a voltage?
Don't go bananas modeling details like load regulation and line regulation if the output serves as the power supply to a sea of digital gates.
Will the model be used in a suite of full chip verification testcases?  If so, even if you need all the details (like load and line regulation) for a few testcases, you certainly do not need those details for the other 98% of testcases.
Or on the other hand, are you doing top-down design and plan to use a model of the LDO as an "executable spec" and designing the LDO schematic later?  In that case you need the model to behave as realistically as possible.
Cheers,
Bob P.
www.RPeruzzi.com
