Jul 20th, 2024, 4:26pm
Schematic against schematic check in cadence (Read 1875 times)
imd1
Feb 28th, 2008, 4:33am
We are re-creating an old design from one obsolete tool into cadence virtuoso. I am wondering if there's any way that I could do an LVS between a cadence schematic (flattened netlist?) and a SPICE deck (the only useful export format of the abandonware) to check if all devices are there , and that they have the correct sizes, etc.
Can Diva do this ? I see no need for Assura, etc. I know it must be possible, somehow. Maybe Caliber ?
Can anyone supply a cookbook solution maybe ?
Thanks in advance!
Smiley
Paul
Switzerland
Re: Schematic against schematic check in cadence
Reply #1 - Mar 18th, 2008, 2:28pm
Basically any LVS tool should be able to do the job. LVS tools first extract a netlist from the layout, then perform netlist-vs-netlist comparison. You can tell these tools (Assura, Calibre, certainly Diva too) to perform the last step only by feeding two netlists. Check the tool documentation for netlist-versus-netlist feature. I know Calibre GUI has a separate tab for that, is pretty straightforward provided your netlists are CDL format (CDL is almost Spice-like).
Paul
jbdavid
Reply #2 - Apr 13th, 2008, 11:08pm
Sabio Labs had some service offerings in this area. they have been recently acquired by Magma DA. If you haven't solved the problem already with Assura or Calibre SVS..
jbdavid
A.D.J
Reply #3 - Jan 4th, 2017, 9:51pm
I just use Calibre to do the SVS (netlist vs netlist). You have to put the spice file into the layout input option. Don't forget the change the top name.
adj
