Jul 16th, 2024, 12:29pm
About the phase noise of the buffer... (Read 6199 times)
Ryan Cheung
Apr 22nd, 2008, 5:07am
Smiley
The input of the buffer is a ideal clock with ideal power supply, and its rist/fall time is constant. If we change its input frequency to half of the original one, a 6dB improvement is achieved as I have expected. However, if the power supply is given from a noisy regulator, the phase noise is degrade about 20dB. This time, if we change its input frequency to half, the 6dB improvement is unreachable. There is only 2dB or even no improvement. I fail to figure out why it is like this.
The simulator used here is pss+pnoise.
Thank you!
rfmems
Re: About the phase noise of the buffer...
Reply #1 - Apr 23rd, 2008, 12:28am
try to seperate the AM noise and PN noise, I think AM noise won't  improve 6dB if you halve your intput frequency
Ryan Cheung
Reply #2 - Apr 24th, 2008, 6:01am
rfmems wrote on Apr 23rd, 2008, 12:28am:
Thanks for your reply
but the noise curve is phase noise. I don't think AM noise is included?
rfmems
Reply #3 - Apr 24th, 2008, 7:34am
the pnoise simulation gives a combined result of phase noise and amplitude noise. Back to your question, I think when the supply is noisy, AM noise can be dominant. That is probably why 6dB improvement is not seen
Reply #4 - Apr 24th, 2008, 7:35am
Ryan Cheung wrote on Apr 24th, 2008, 6:01am:
Result of PSS/Pnoise is no more than small signal mixing noise. So AM noise appears in Pnoise results.
Ryan Cheung
Reply #5 - Apr 25th, 2008, 10:52pm
pancho_hideboo wrote on Apr 24th, 2008, 7:35am:
Thanks again for all of your replies! Wink
Does the AM noise that you mentioned here is the AM-PM noise part? There is no pure AM noise because of the amplitude limiting mechanism. Did you mean that the part of phase noise originating from AM noise will not achieve a 6dB improvement? Why is it?
What I think is the noise could only disturb the circuit at rise/fall time, and this lead to a fixed amount of jitter. If the rise/fall time is fixed, the jitter is fixed. So if the period is double, its phase noise should achieve a 6dB improvement. Am I right?
Thanks!
rfmems
Reply #6 - Apr 26th, 2008, 2:11am
I think when your power supplye is noisy, assumption of hard limit is not valid.
Claims like there is only phase noise is no better than an approximation
Ryan Cheung
Reply #7 - Apr 29th, 2008, 4:12am
rfmems wrote on Apr 26th, 2008, 2:11am:
I have got your idea! Smiley
But if I want to achieve the phase noise, how should I configure the spectreRF simulator?
There is a 'noise type' option in pnoise analysis, which default to 'sources'. If I set 'noise type=modulated', the simulator could give a PM noise and an AM noise. Does this PM noise is the phase noise?
If I set 'noise type=jitter', the simulator give a 'tdnoise'. What the relationship between the 'tdnoise' and the phase noise?
Any anwser is appreciated!
