Jul 16th, 2024, 12:50pm
How to simulate the NF of a circuit with high input impedance?? (Read 3680 times)
zhangjerome
Jun 30th, 2008, 10:42pm
A 50-ohms port is used as the input noise source. Somebody told me to place a extra 50 ohms resistor in parallel with this port to simulate the NF of the circuit. Is it right??
Same questions arises in the IIp3 simulation for the same circuit. Is it right to place a resistor in parallel with the port?
Thank you.
aaron_do
Re: How to simulate the NF of a circuit with high input impedance??
Reply #1 - Jul 1st, 2008, 12:34am
you could simulate the Input Referred Noise instead (V2/Hz). Same goes with IIP3. You can simulate the input referred IIP3 in terms of voltage. Remember NF is defined as
total Nout
Nout due to source
cheers,
Aaron
Reply #2 - Jul 1st, 2008, 1:30am
zhangjerome wrote on Jun 30th, 2008, 10:42pm:
Generally it is not correct.
See the follwing.
http://www.designers-guide.org/Forum/YaBB.pl?num=1194006190
As far as lumped component level simulation, such shunt 50ohm is not needed. In this case, you don't have to use port. You might use vsource depending on your application and purpose.
But if you use actual signal generator of relative high frequency, such shunt 50ohm might be needed since signal is fed through 50ohm line.
See http://www.designers-guide.org/Forum/YaBB.pl?num=1207009725
« Last Edit: Jul 1st, 2008, 4:16am by pancho_hideboo »
