Jul 16th, 2024, 12:40pm
SP simulation and negative real Y (Read 8171 times)
xristigi
Aug 13th, 2008, 6:56am
Hello everybody,
I have been running sp simulation to find the equivalent parallel impedance in a node of my circuits and it seems that :
Yreal=-1m
and Yimag=3m
Should I worry for this negative real part?? Does it imply instability??
What does it mean exactly?
Thanks in advance
Re: SP simulation and negative real Y
Reply #1 - Aug 13th, 2008, 8:38am
xristigi wrote on Aug 13th, 2008, 6:56am:
Yreal=-1m
and Yimag=3m
It could be conditionally stable.
« Last Edit: Aug 13th, 2008, 5:31pm by pancho_hideboo »
xristigi
Reply #2 - Aug 13th, 2008, 9:02am
I also came to that conclusion... I also realized that it is due to the emitter followers that I have connected there. I guess I should check stability for the given source impedance.
Thanks again
Reply #3 - Aug 13th, 2008, 9:19am
xristigi wrote on Aug 13th, 2008, 9:02am:
You have to check stability both for source and load impedances.
buddypoor
Bremen, Germany
Reply #4 - Aug 13th, 2008, 10:12am
Quote pancho_hideboo: It's conditionally stable
Conditional stability is a specific term from the control theory describing a system which can be stabilized by increasing the loop gain.
Presently, I cannot see how one can come to the conclusion that a negative real part of the input conductance of a system indicates this kind of "conditional stability". Perhaps something else is ment ?
Question to pancho_hideboo: What does this mean for the system under discussion ? What has to be done to destabilize the system or to keep it stable ?
Reply #5 - Aug 13th, 2008, 5:04pm
buddypoor wrote on Aug 13th, 2008, 10:12am:
No, you are wrong. Maybe you are not familiar with RF circuit theory.
Terms, "Conditionally Stable" and "Unconditionally Stable" are also used in RF circuit.
But these can not be completely related to stability theorem in control system theory.
http://www.designers-guide.org/Forum/YaBB.pl?num=1190272820
We can judge whether an amplifier is unconditionally stable or not by well-known K-factor or Mu-factor.
See stab_fact() and mu() in "Chapter 9: S-Parameter Analysis Functions" of the following.
http://cp.literature.agilent.com/litweb/pdf/ads2005a/pdf/expmeas.pdf
Assume a simple amplifier. Here I define followings.
  Gamma_S=Source Reflection Coefficient
  Gamma_In=Input Reflection Coefficient
  Gamma_L=Load Reflection Coefficient
  Gamma_Out=Output Reflection Coefficient
  StabFactor_S=real(Gamma_S*Gamma_In)
  StabFactor_L=real(Gamma_L*Gamma_Out)
If both StabFactor_S<1.0 and StabFactor_L<1.0 are satisfied, this amplifier is stable. This is conditionally stability.
And this conditionally stability could be satisfied even if input impedance or ouput impedance have negative real part.
This stability is dependent on source and load impedances.
For example, when an input of amplifier is left open or short, abs(Gamma_S)=1.0. If this amplifier has real(Yin)<0 or real(Zin)<0, abs(Gamma_In)>1.0. So this amplifier could not be stable.
For example, an amplifier of real(Yin)<0 could be stable if shunt conductance is inserted at input of amplifier so that it cancels real(Yin)<0.
Of cource, this too simple stabilizer degrades gain of amplifier.
« Last Edit: Aug 14th, 2008, 12:12am by pancho_hideboo »
