microant
China,SH
Hi Rajdeep
You can run AC analysis alonely. first, in the 'initial condition...' add the init value for the net, then, in the option for AC analysis, setup with force=all, oppoint=logfile, restart=no. after this, you can run the simulation and the OP info you will see in the output log.
BR, Lin
