Sep 18th, 2026, 8:28am
Conditional AEL in CDF (Cadence/icfb)? (Read 2159 times)
Haydar
Portland, OR
Jan 22nd, 2009, 12:07pm
Can I have a conditional expression in the CDF to determine a device value? The AEL document lists "?:" as a valid operator but it didn't work for me.
For example, assuming p1 is already defined and I try to make the value of the resistor r dependent on the value of parameter p1.
(iPar("p1")==1) ? 10 : 20
-Haydar
Re: Conditional AEL in CDF (Cadence/icfb)?
Reply #1 - Jan 22nd, 2009, 4:24pm
The ternary operator is supported in AEL, as the code below shows:
> e=aelEnvCreate("f")
aelEnv:0x08e38018
> aelEnvInterpret(e "1==1?10:20")
"10.0"
> aelEnvInterpret(e "1==2?10:20")
"20.0"
How did you test it? Was it for a particular netlister? For example, the spectre netlister wouldn't fully evaluate the expression (I think) - it would end up in the netlist (the iPar would get replaced), but spectre can also handle this expression.
Haydar
Portland, OR
Reply #2 - Jan 23rd, 2009, 1:41pm
I test this under the Tools->CDF->Edit tab, not through skill code.
I tried some more and have somewhat puzzling results:
For a resistor which has parameters p1, p2, p3 added,
I make the resistor value r dependent on parameter values via a conditional and observe these:
(iPar("p1")==1)?10:20                        -> Works
(iPar("p1")==1)?iPar("p2"):20             -> Works
(iPar("p1")==1)?iPar("p2"):iPar("p3")   -> Doesn't work
When it doesn't work, Virtuoso schematic shows "*Error*" on the schematic, otherwise it shows the actual evaluated value.
-Haydar
« Last Edit: Jan 23rd, 2009, 4:00pm by Haydar »
Reply #3 - Jan 27th, 2009, 1:20pm
I did some tests, and put together a component with CDF as you describe. I got an error on the label when it tried to evaluate it, so I called
artSetDetailedLabelErrorFlag(t)
as suggested in the CIW. When I do this I get an error in the attached picture. I tried adding some extra parentheses, but it didn't help...
You should contact Cadence customer support and report this.
