aamar
Hallo,
Is it possible to edit the DC Operating point parameters shown for a transistor using the Annotate DC Operating point? Earlier I was able to see the Vgs and Vds of MOSFETS on the schematic, after a software update, I see now the gm, vdsat and others but no voltages.
The other problem is that if I Annotate the DC node voltages, the voltage of internal nodes of blocks are not shown. The only possible way is to use the results browser to check the node voltages which is not the easy way in my opinion. Is it possible to show the voltages of the internal nodes?
aamar
