May 19th, 2024, 6:17am
Annotating DC operating points (Read 6920 times)
aamar
Mar 13th, 2009, 8:43am
Hallo,
Is it possible to edit the DC Operating point parameters shown for a transistor using the Annotate DC Operating point? Earlier I was able to see the Vgs and Vds of MOSFETS on the schematic, after a software update, I see now the gm, vdsat and others but no voltages.
The other problem is that if I Annotate the DC node voltages, the voltage of internal nodes of blocks are not shown. The only possible way is to use the results browser to check the node voltages which is not the easy  way in my opinion. Is it possible to show the voltages of the internal nodes?
aamar
Re: Annotating DC operating points
Reply #1 - Mar 13th, 2009, 9:17am
You have to show tool's name you use regarding simulator and design environment(entry tool, framework).
aamar
Reply #2 - Mar 13th, 2009, 9:24am
I am using cadence, the Virtuoso Schematic Editor.  And the simulator is MMSIM7.0.
is that what you asked about?
thanks,
aamar
Reply #3 - Mar 13th, 2009, 9:33am
aamar wrote on Mar 13th, 2009, 9:24am:
Yes.
Use "Edit>Label Display" in menu of Schematic Window.
