Jul 17th, 2024, 6:31pm
two tone simulation for pipeline ADC (Read 10254 times)
prem
Nov 26th, 2008, 9:52pm
hi,
i am planning to perform a two tone simulation for a pipeline ADC (9 BIT 2s compliment ADC).Can any one help me to get some idea on two tone simulation....
Paul
Switzerland
Re: two tone simulation for pipeline ADC
Reply #1 - Nov 27th, 2008, 12:35pm
Could you formulate the specific question you have? Try to have a look at the following posts in the forum to get started:
http://www.designers-guide.org/Forum/YaBB.pl?num=1134545463
http://www.designers-guide.org/Forum/YaBB.pl?num=1169820193
Paul
jbdavid
Reply #2 - Dec 10th, 2008, 5:26pm
Pull your bow across two strings at the same time.. ?
jbdavid
prem
Reply #3 - Jan 1st, 2009, 6:42am
hi,
My input frequencys are 6.875M and 8.75M and the maximum sampling frequncy of the ADC is 80M.Can any one tell is there any criteria in selecting the sampling frequency as in the case of single tone coherent sampling method.
Reply #4 - Jan 24th, 2009, 7:06am
Prem,
I think that two tone simulation requires coherent sampling, too. First of all, decide how many points do you want to sample? Then calculate the signal frequencies for both tones following the rule in the case of one tone coherent simulation. Please notice each tone is of half amplitude to prevent the ADC from clipping (saturation).
Yawei
