Jul 16th, 2024, 4:04pm
Tline and DC in Spectre (Read 265 times)
kevinvinv
Jan 07th, 2009, 8:16am
Hey I've got a question about how the TLine model works in Spectre.
I specify Zo=50 and Td=10ns
I am checking things out however, at DC.
The symbol looks something like this
   a-----xxxxxxxxxxxx-------b
   c-----xxxxxxxxxxxx-------d
At DC,   shouldn't   a and b actually be connected to each other- and not to c/d?
and shouldn't   c and d actually be connected to each other and not to a/b?
This is not how things are looking actually...   and it is puzzling to me.  I guess I have never looked at tline behavior before at DC but now I need too...
thoughts?
__________________
Kevin
Re: Tline and DC in Spectre
Reply #1 - Jan 7th, 2009, 5:00pm
Your post is usage of simulator not Design issue.
Please post to "The Designer's Guide Community Forum ≫ Simulators ≫ Circuit Simulators".
kevinvinv wrote on Jan 7th, 2009, 8:16am:
You are misunderstanding tline. tline is not differential line(coupled line).
See "spectre -h tline".
Quote:
Only the odd mode is modeled, so only the voltage difference across each port is important.
(The absolute voltage of each terminal is not significant.)
Also, the current into one node of a port exactly equals the current leaving the other node of the port.
Also see Chapter-7 of the following.
http://cp.literature.agilent.com/litweb/pdf/ads2005a/pdf/ccdist.pdf
"TLIN4 (Ideal 4-Terminal Transmission Line)" is most close to "tline of Cadence Spectre".
Here Pins 2 and 4 need to be appropriately grounded for correct usage of this component.
In your case, nodes "c" and "d" need to be grounded.
"tline of Cadence Spectre" is not coupled line such as "CLIN (Ideal Coupled Transmission Lines)".
Attached is a extraction from HSPICE manual.
In your case, "a"->"in", "b"->"out", "c"->"refin", "d"->"refout".
« Last Edit: Jan 7th, 2009, 9:49pm by pancho_hideboo »
Reply #2 - Jan 7th, 2009, 9:52pm
The tline model in Spectre and SPICE is perfectly happy having different DC voltages on the outer conductors at both ends of the lines.
Let
     Vi1 = voltage on inner conductor of port 1
     Vo1 = voltage on outer conductor of port 1
     Vi2 = voltage on inner conductor of port 2
     Vo2 = voltage on outer conductor of port 2
Then in DC the transmission line enforces that
     Vi1 - Vo1 = Vi1 - Vo2
In other words it models the odd mode, which is RF jargon for the differential mode.  It allows Vo1 != Vo2, which means it is not modeling the even mode (or the common mode).
To model both even and odd modes in a coax configuration, use the following subcircuit (note that this model is non-symmetric).
subckt coax (i1 o1 i2 o2)
   parameters zinner=50 zouter=50 vinner=1 vouter=1 td=1
   inner i1 o1 i2 o2  tline z0=zinner vel=vinner td=td
   outer o1 0  o2 0   tline z0=zouter vel=vouter td=td
ends coax
To model both even and odd modes in a twisted-pair configuration, use the following subcircuit (note that this model is symmetric).
subckt twisted (p1 n1 p2 n2)
   parameters zodd=50 zeven=50 veven=1 vodd=1 td=1
   odd  p1 n1 p2 n2  tline z0=zodd vel=vodd td=td
   tf1a p1 0  e1 c1  transformer t1=2 t2=1
   tf1b n1 0  c1 0   transformer t1=2 t2=1
   even e1 0  e2 0   tline z0=zeven vel=veven td=td
   tf2a p2 0  e2 c2  transformer t1=2 t2=1
   tf2b n2 0  c2 0   transformer t1=2 t2=1
ends twisted
Reply #3 - Jan 7th, 2009, 10:14pm
This is symmetrical coupled line using two tline.
Ken's definition of Zeven and Zodd is wrong.
If you refer data sheet of transmission line, Zeven and Zodd must be following.
Zeven=2*Zcommon
Zodd=0.5*Zdiff
