Aug 16th, 2024, 1:23am
power delivered to load - pss analysis (Read 2738 times)
tempora123
Feb 25th, 2009, 1:43am
I have set up a simple circuit. Port with 50 Ohm internal resistance and 100 Ohm load resistor. I would like to deliver fixed power to this resistor. Therefore, I set up 1dBm power property on PORT. With reflection coefficient of 0.333(3) (for voltage) or 0.111(1) (for power) I expect that the forward power increase factor is 1/(1-0.333^2)=1.125. This means the power delivered from PORT is 1.125dBm, reflected power is 1.125dBm * 0.111(1)=0.125dBm and the power delivered to load is 1.125dBm - 0.125dBm=1dBm.
When I run pss analysis and check Results -> Direct plot -> Main form -> Power and click on the terminal of the 100Ohm load resistor I get 0.4885dBm.
Can anyone explain this number?
Thank you.
subgold
Re: power delivered to load - pss analysis
Reply #1 - Feb 25th, 2009, 2:39am
hi,
i think your calculation is wrong. how come the power delivered from the PORT is larger than its own power? Also, you forgot to convert the factor into db.
the cadence result is simply 1dbm-10log(1-0.111).
Reply #2 - Feb 25th, 2009, 5:52am
See http://www.designers-guide.org/Forum/YaBB.pl?num=1235497885/1#1
tempora123 wrote on Feb 25th, 2009, 1:43am:
Pinc=Pdis/(1-abs(Gamma)**2)
But power value set in port is Pinc not Pdis.
This is your misunderstanding.
This 0.4885dBm is Pdis for Pinc=1dBm at Gamma=1/3.
tempora123
Reply #3 - Feb 25th, 2009, 10:03am
thanks for your replies. It seems clear now.
br
