Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 16
th
, 2024, 3:20am
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› import external device model in to Cadence
Previous topic
Next topic
import external device model in to Cadence (Read 3905 times)
cashAZ
Feb 05
th
, 2009, 2:48pm
I have a model for an external diode. The model has been provide by a vendor in spice format. The diode is in my top level verification test. How do I import this model and link it to the diode symbol in my test bench.
IP Logged
Re: import external device model in to Cadence
Reply #1 -
Feb 5
th
, 2009, 3:55pm
This post should help
http://www.designers-guide.org/Forum/YaBB.pl?num=1118940189/1#1
. Note that it applies even if the file just contains a model definition rather than a subckt definition.
IP Logged
cashAZ
Reply #2 -
Feb 6
th
, 2009, 8:36am
Hi Andrew,
Thanks that helped out a lot. One problem I am still having is the model is actually in P-spice format. Spectre seems to be having problems reading that format. Is there a document on converting from Pspice to spectre?
Dave
IP Logged
Reply #3 -
Feb 6
th
, 2009, 9:45am
Don't think so, sorry. Normally it's only an issue if it's using PSPICE "behavioral" constructs - normal devices are normally OK.
IP Logged
Reply #4 -
Feb 26
th
, 2009, 6:20am
Is it complaining about the syntax (.model) or a parameter? Spectre might be thinking the file is in Spectre format.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
