Jul 17th, 2024, 8:32am
AC analysis in verilog-ams (Read 2399 times)
Alex83
Mar 15th, 2009, 12:24pm
Hi All,
I am new to this forum and also to Verilog-AMS.
I would like to use some testbenches made of varilog-ams blocks for AC analysis especially for testing stability and bandwidth.
Can someone tell me if this is possible? If yes how is possible if every blocks is made of code insted of R and C? Who generates the poles and the zeros?
Many thanks
« Last Edit: Mar 15th, 2009, 2:58pm by Alex83 »
Re: AC analysis in verilog-ams
Reply #1 - Mar 16th, 2009, 5:33am
Yes, it's possible -- if the Verilog-AMS modules are written correctly.
You can write a resistor as I(a,b) <+ V(a,b) / R; and a capacitor as I(t,b) <+ ddt(C * V(a,b));
You might want to read up on how Spice does an ac analysis (see the DG to Spice and Spectre).  The idea is that Spice linearizes the entire circuit around the operating point, so you have to have your AMS modules written so that their derivatives (the linearization) are correct at any operating point.
sand_dolphin2
Japan
Reply #2 - Oct 26th, 2009, 4:30pm
Geoffrey_Coram wrote on Mar 16th, 2009, 5:33am:
sorry for continue discussing about this thread.
i want to make AC analysis bellow case w/t verilog-HDL and Verilog-AMS.
  input analog V(Vin) => AD comparator(verilog-AMS)
   => LOGIC(verilog-HDL)
   => DA comparator(verilog-AMS) => output analog V(Vout)
I want to make AC analysis btw Vin and Vout.
this case, should be use both logic and spice simulator.
plz let me know how to use function or tool for AC analysis. Sad
I'm waiting for your advice Smiley
See you soon again Wink
ciao
boe
Reply #3 - Oct 30th, 2009, 11:37am
sand_dolphin2 wrote on Oct 26th, 2009, 4:30pm:
The AC simulation is a small-signal analysis based on Fourier/Laplace transform of linear systems.
However your system contains several sources of non-linearity:
AD converter:
1. Quantization (highly non-linear for small signals [say, a few LSBs])
2. Clamping
3. Folding (for signal frequencies > fsample/2)
Logic:
4. depending on functionality.
DA converter:
5. Non-ideality
Therefore, there is no general solution to this, in particular w.r.t. items 1 and 4.
BOE
NB: Kens advice in http://www.designers-guide.org/Forum/YaBB.pl?num=1252743617
sand_dolphin2
Japan
Reply #4 - Nov 2nd, 2009, 12:10am
Dear Boe!!
at first, I apologize my much late response ( 1 week )...
boe wrote on Oct 30th, 2009, 11:37am:
AD converter:
2. Clamping
Logic:
DA converter:
5. Non-ideality
BOE
ohps!! Sad I fully(?) understand your mentioned. that's right.
Sorry for my easy idea for asking AC analysis w/t Logic function.
 but in future, we should solve this item. Embarrassed
 how about your opinion?
 Is there no way only w/t 3,4 your mentioned case ?
 maybe these points are the most important points.....
How to treat digital filter behavior depend on frq on AC analysis.
i want to solve .... not now but future. is it far from now? Huh
boe
Reply #5 - Nov 2nd, 2009, 3:58am
sand_dolphin2,
Just a few ideas:
If we ignore errors from 1,2 and 5, and your digital block implements a digital filter, you are asking how to simulate a real-valued (= not quantized) discrete-time filter. For this, use sim strategy as for SC filters, which are also real-valued and time-discrete.
You could use Verilog-A models and PSS/PAC simulation of Spectre(RF), See e.g replies to http://www.designers-guide.org/Forum/YaBB.pl?num=1134027466 or http://www.designers-guide.org/Forum/YaBB.pl?num=1147370163.
MATLAB might also be a useful tool.
BOE
Reply #6 - Nov 3rd, 2009, 3:58am
Not correct.
boe wrote on Nov 2nd, 2009, 3:58am:
You can not adopt PSS/PAC of Cadence Spectre to behavioral model simulation of Digital Filter or SCF using Verilog-A generally since there are hidden states.
http://www.designers-guide.org/Forum/YaBB.pl?num=1210932698/1#1
MATLAB is different from Simulink.
Use cosimulation between spice type transient simulator and logic simulator.
http://www.designers-guide.org/Forum/YaBB.pl?num=1238242506/1#1
Here driving Vin by sinusoidal signal with varying frequency, you can evaluate frequency characteristics between Vin and Vout.
sand_dolphin2
Japan
Reply #7 - Nov 4th, 2009, 4:12pm
Dear Kita━━━━━━(゚∀゚)━━━━━━ !!!!!(i can't write down Panxxboo)
pancho_hideboo wrote on Nov 3rd, 2009, 3:58am:
so, at now we provide varying frequency from testbench.
and  dumpinig data frome results Vin/Vout transfer to excell csv format.
but, i want to automatically checking AC analysis w/o handmade making varying frequency input by testbench.
but this way is so take a much time to simulate....
Is it possible AC analysys of DUT(like as verilog-A(electrical only)) by spice's AC analysis which force automatically various freq.
I'll wait for your kindly responce. Roll Eyes
Reply #8 - Nov 5th, 2009, 7:41am
sand_dolphin2 wrote on Nov 4th, 2009, 4:12pm:
What procedure do you take and what instruments do you use in actual evaluation ?
Consider actual situation of evaluation.
Show me your realization method of AC Analysis in actual evaluation.
Learn measurements using actual instruments. Not "EDA Tool Play".
Do you understand AC Analysys correctly ?
If your intererst is limited to very narrow aspect of DUT, you might be able to use high abstract level modeling for DUT.
For example, if you can build "State Averaged Model" for target DUT, you can adopt conventional AC Analysis.
This "State Averaged Modeling" is well known as "Describing Function Method" or "Equivalent Transfer Function Method"
in Nonlinear Control Theory.
Equivalent Lowpass Model of RF Bandpass System is this "State Averaged Modeling".
Phase Domain Model of PLL is also this "State Averaged Modeling".
If you can know Z-domain Transfer function of Digital Filter or SCF, you can use conventional AC Analysis for evaluation of frequency characteristics of them.
What on earth do you expect for Verilog-AMS ?
Functional Verification ?
High Abstract Level Modeling of DUT with very narrow aspect ?
« Last Edit: Nov 5th, 2009, 8:57am by pancho_hideboo »
sand_dolphin2
Japan
Reply #9 - Nov 8th, 2009, 10:02pm
pancho_hideboo wrote on Nov 5th, 2009, 7:41am:
Would you mind to let me know more about this methods( conventional AC Analysis ) ?
limited in my cace, finally means
 only to check Digital filter's AC analysis which you mentioned. Sad
Quote:
are you kidding? Undecided (killing?)
anyway thank you so much for your kind.
ciao! Wink
Reply #10 - Nov 8th, 2009, 10:29pm
sand_dolphin2 wrote on Nov 8th, 2009, 10:02pm:
Still your expression is wrong.
It has to be "Evaluation of Digital filter's Frequency Characteristics".
Generally you have to use Transient Analysis for "Evaluation of Digital filter's Frequency Characteristics".
Here frequency characteristics is evaluated by DFT of impulse response.
Again see http://www.designers-guide.org/Forum/YaBB.pl?num=1210932698/1#1
If you want to use AC analysis for "Evaluation of Digital filter's Frequency Characteristics",
you have to describe transfer function as Z-domain expression.
That's all.
Still if you can't understand,
sand_dolphin2
Japan
Reply #11 - Nov 9th, 2009, 12:02am
pancho_hideboo wrote on Nov 8th, 2009, 10:29pm:
Thank you so much for your correct!!
I fully understand your mentioned(maybe will be ...).
ciao Wink
