Jul 17th, 2024, 6:20am
Does can i declare CDF Parameter as global parameter (Read 1822 times)
somisetty
Nov 09th, 2009, 2:35am
Does can i declare CDF Parameter as global parameter for top module in spectre. If yes, how is it?
Thanks in advance
Riad KACED
Swindon, UK
Re: Does can i declare CDF Parameter as global parameter
Reply #1 - Nov 9th, 2009, 11:39am
Your question is not clear at all !
Can you say what you want to do ?
Please move your question to a more appropriate forum as what you are asking for has nothing to do with Verilog-AMS.
Cheers,
Riad.
Riad KACED
PDK, EDA Support Engineer.
