Jul 17th, 2024, 12:18am
Hole Pattern Error in Momentum simulation. (Read 4722 times)
silentboy
Mar 23rd, 2009, 11:27am
I am running momentum simulation for a differential inductor and got error information:
Found Hole pattern inside hole pattern.
Doese anyone have any idea what caused this problem?
Thanks a lot!
Re: Hole Pattern Error in Momentum simulation.
Reply #1 - Mar 23rd, 2009, 8:23pm
silentboy wrote on Mar 23rd, 2009, 11:27am:
Did you replace a grid of tiny square vias with one large via of equivalent cumulative via ?
Probably there are some vias left from the old array inside the new one and this is mapped on a different layer.
Also see the following.
https://edasupportweb.soco.agilent.com/portal/page?_pageid=36,39953&_dad=portal&...
EEsof Knowledge Center > Documents > Support Documents > ADS > Momentum > Simulation
ADS : Momentum : ERROR : More than two segments overlap in geometry. Please modify geometry.
Document ID : 270284
« Last Edit: Mar 24th, 2009, 4:44am by pancho_hideboo »
