Aug 17th, 2024, 1:09pm
PSRR of VCO (Read 9733 times)
sivankumarpsp
India
PSRR of VCO
Mar 26th, 2009, 12:40am
How do i measure the PSRR for VCO? What is the exact definition of PSRR for VCO? I am trying to give a sine wave of some frequency at the supply and trying to find out the change in the frequency and then take the ratio of frequency change/supply chage. Is it correct? can any one explain?
View Profile sivankumarpsp sivankumar sivan_75   IP Logged
raja.cedt
Re: PSRR of VCO
Reply #1 - Mar 26th, 2009, 1:16am
hi,
   whats your supply noise profile,because if it is  really contains  only one harmonic then sine is  ok..but most of the supply noise spectrum's  are like band pass  pass with cutoff frequency in mega hertz.so better always  apply square wave with magnitude based on the peak of the spur in noise spectrum(some times people find PSRR by using AC analysis,but this is acceptable when noise magnitude is very low,but now a days noise having considerable magnitude and that to your doing PLL i guess..so you have to use square wave with proper rise time).I don't think variation in frequency is important..because any how PLL loop with take care..so rather than finding frequency variation find change in Kvco..because it will effect loop dynamics...
   with my very less design experience i gave the above ans..please correct me if i am wrong
Rajasekhar.
Visjnoe
Re: PSRR of VCO
Reply #2 - Mar 26th, 2009, 8:08am
Several things can be checked here:
1. Sensitivity of the VCO frequency with regard to supply variations.
As mentioned, typically not very relevant since the PLL will *eventually* counteract the change...but take care! If the changes happen faster than your PLL/loop can follow, you will see an effect.
2. The appearance of spurs in the VCO spectrum due to tones on the supply. See theory about FM modulation. If possible use a separate regulator for your VCO and don't run anything else from it.
What tones can you expect? Look at your system: harmonics or mixing products of clocks.
Peter
raja.cedt
Re: PSRR of VCO
Reply #3 - Mar 26th, 2009, 12:15pm
hi peter,
           Thanks for your reply,if i use any seperate Regulator only for VCO that's fine...i think in that case for PSRR ac analisys is enough,but its bandwidth should be very high..In your reply i have one doubt..even though VCO frequency changes and finally after several cycles PLL will correct even thogh it's bandwidth is low
Rajasekhar.
sivankumarpsp
India
Re: PSRR of VCO
Reply #4 - Mar 30th, 2009, 6:08am
Thanks a lot for your answers. Can i do PSS and PNOISE analysis to find out the phase noise in the output of VCO due to the ripples in the supply? If that can be done, what kind of test bench i need to make?
Sivan
Re: PSRR of VCO
Reply #5 - Mar 30th, 2009, 4:04pm
You would use PXF.
sivankumarpsp
India
Re: PSRR of VCO
Reply #6 - Mar 30th, 2009, 9:18pm
Can any one give me some idea how to use PXF simulation for finding out phase noise?
Sivan
Re: PSRR of VCO
Reply #7 - Mar 31st, 2009, 3:18am
I presume you don't really mean phase noise? For that you'd use pnoise analysis.
To find the transfer function from a perturbation on the supply to the output of the VCO, you'd use PXF, as Ken says. There is also the "modulated" mode of PXF, which allows you to separate the PM and AM components of the modulation - some of the supply variation may not affect the frequency, but just the amplitude  - so being able to separate them may be useful.
To run PXF, you wouldn't apply any varying signal on the supply - you'd tell PXF where the output of the circuit is, and the output frequency (much as you'd specify the output for pnoise). Then when the simulation is finished, you can use the direct plot form to click on the source for the supply, and see the transfer function(s) from this source to the outputs.
Yutao Liu
Guangzhou, China
Re: PSRR of VCO
Reply #8 - Sep 5th, 2009, 1:20am
Andrew Beckett wrote on Mar 31st, 2009, 3:18am:
Hello Andrew, I have the same question as Sivan's.
Since PXF gives us the transfer function from the power supply to the output of VCO, we only get to know VCO's power supply sensitivity, which is not the phase noise due to the ripple on supply path.
And in the "modulated" mode in PXF, even when PM is chosen in "Main Form", I only get the phase component of modulation from power supply to output of vco, not the phase noise yet.
Do you have any idea to change this result to the phase noise contributed by supply noise?
Yutao
