Aug 18th, 2024, 11:23pm
Choose which version of assura for IC610? (Read 4089 times)
nuoan
Apr 14th, 2009, 4:25pm
I have installed IC610, which version of assura should I install?
Thanks!
Re: Choose which version of assura for IC610?
Reply #1 - Apr 15th, 2009, 2:31am
Well, are you using IC613 (i.e. the latest Hotfix version, or the update version - I would really recommend going for the latest hotfix)?
If so, you should use the latest ASSURA32 version for 6.1.3. If you look on downloads.cadence.com under ASSURA32 you'll see various versions for different releases (for 6.1.1, for 6.1.2, for 6.1.3 and for CDB (i.e. IC5141)). Pick the most recent one - this is currently the Hotfix version:
13 Mar 2009         ASSURA03.20.018, Version: ASSURA32USR2HF5OA_613
By the way, this is posted in completely the wrong board...
nuoan
Reply #2 - Apr 15th, 2009, 5:31pm
Hi Andrew,
Thanks, I will download ASSURA03.20.018 as soon as possible
