Jul 17th, 2024, 3:36pm
how to measure phase noise of PLL? (Read 2978 times)
liletian
MD
May 09th, 2009, 5:56pm
 Hi Guys
 I would like to measure phase noise of my PLL, I had spectrum analysize, is there a tutorial how to measure phase noise?
 Thank you
Re: how to measure phase noise of PLL?
Reply #1 - May 9th, 2009, 6:38pm
liletian wrote on May 9th, 2009, 5:56pm:
What is spectrum analysize ?
If you mean "Spectrum Analyzer", show me product number and options you have.
If you have "Phase Noise Measurement" option, measuring phase noise is very straightforward.
However I don't think your PLL can reach to valuable level to evaluate phase noise.
Do you understand "Comparison Frequency" ?
http://www.designers-guide.org/Forum/YaBB.pl?num=1241452951/8#8
« Last Edit: May 10th, 2009, 8:41am by pancho_hideboo »
liletian
MD
Reply #2 - May 9th, 2009, 7:08pm
[quote author=pancho_hideboo link=1241917016/0#1 date=1241919530]liletian wrote on May 9th, 2009, 5:56pm:
Agilent N9020A
not really yet, if you can explain, I will appreciate it.
thank you
Reply #3 - May 10th, 2009, 8:47am
liletian wrote on May 9th, 2009, 7:08pm:
pancho_hideboo wrote on May 9th, 2009, 6:38pm:
Agilent N9020A
Do you have "N9068A Phase Noise Measurement Application" ?
http://www.home.agilent.com/agilent/product.jspx?cc=US&lc=eng&ckey=842945&nid=-3...
If you have this N9068A, measuring phase noise is very straightforward.
I'm not kind and patient enough for explaining such too basic issues.
Other people who is very kind and patient will help you.
rfmems
Reply #4 - May 10th, 2009, 11:18pm
Hi liletian,
In your pll, you vco frequency has to be divided and then compared in PD/PFD with your reference.
I guess you are desiging/measuring a pll with external loop filter, if that is the case, please read dean's book, availble at http://wireless.national.com.
love_analog
Reply #5 - Apr 27th, 2010, 9:26pm
Just use a spectrum analyzer. Put your PLL output in it and the spectrum analyzer will give you exactly the phase noise at each frequency point in dbc/Hz
loveanalog.blogspot.com
The Power of Analog
Reply #6 - Apr 28th, 2010, 8:52am
love_analog wrote on Apr 27th, 2010, 9:26pm:
Not correct.
It is a CNR not true phase noise if you use conventional Spectrum Analyzer without phase noise measurement option.
First, you can't measure CNR for very small offset frequency if you use conventional Spectrum Analyzer.
Second, it is no more than normalized sideband noise not PM noise if you use conventional Spectrum Analyzer.
See the followings.
http://www.designers-guide.org/Forum/YaBB.pl?num=1050465395/22#22
http://www.designers-guide.org/Forum/YaBB.pl?num=1256925601/4#4
« Last Edit: Apr 28th, 2010, 11:45am by pancho_hideboo »
love_analog
Reply #7 - May 1st, 2010, 8:51am
I need a little education here because that is what I have been using throughout.
I understand a spectrum analyzer cannot distinguish between AM and PM noise. However, typically AM noise is at a much higher frequency >> 1Mhz so I do not care that much about the split at ~1Meg
My understand was the dbc/Hz read is really the phase noise.
What is CNR? In a practical scenario, how much difference is there between the "real" phase noise and the reading from a spectrum analyzer.
The Power of Analog
Reply #8 - May 1st, 2010, 9:17am
love_analog wrote on May 1st, 2010, 8:51am:
No.
It is no more than C/N0 ; Carrier Power to Noise Power Density Ratio
What is CNR?
C/N ; Carrier Power to Noise Power Ratio.
Noise Marker Mode in conventional Spectrum Analyzer shows C/N0 or C/N.
I don't have good examples now.
I can't measure C/N0 at small offset frequency correctly using conventional Spectrum Analyzer.
I have many instruments as well as EDA tools.
When I have spare time, I will create actual measurement examples.
We can't measure Carrier Power correctly because we can't separate carrier and noise clearly in actual measurement.
On the other hand, carrier and noise are evaluated separately in small signal noise analysis subjected to master steady state large signal analysis such as Cadence Spectre PSS/Pnoise.
« Last Edit: May 1st, 2010, 10:54am by pancho_hideboo »
love_analog
Reply #9 - May 1st, 2010, 9:52am
Now I know what you are saying. Yes, spectrum analyzer measures Sv(f) whereas what we really want is Sphi(f).
2 Question
a) Apart from very close to center frequency, these 2 quantities should be the same? Although I realize that "very close" is not well defined but I presume its a few KHz of the center, or maybe its the point where Sv(f) is flatenning out
b) If I am wrong, what method do you suggest to measure phase noise (if we do not use a spectrum analyzer)
thanks
The Power of Analog
Reply #10 - May 4th, 2010, 12:11pm
