Nov 19th, 2024, 3:38am
Pages: 1 2
startup circuit..initial conditions..trans sim (Read 4534 times)
somisetty
May 19th, 2009, 7:53am
hi,
would pls let me know what need to be the initial condition for the nodes to test the startup circuit transient sim?
FYI:pls find the circuit  attached with nodes labeled...
Thanks a lot....
raja.cedt
Re: startup circuit..initial conditions..trans sim
Reply #1 - May 19th, 2009, 8:17am
hi somisetty,
                 i didn't understand your question because if you don't have any start up circuit and you want to check weather your ckt is working or not then initializes one of the node to some intermediate potential..
But you already have start up circuit,so during starting v- will be at zero potential so some current will flow through Q2 hence ckt  will start so don't think this need any internalization.
Rajasekhar.
salty
Austin, Tx
Reply #2 - May 19th, 2009, 9:12am
You could ramp your supply, that should allow you to see the start-up ckt. working.
somisetty
Reply #3 - May 19th, 2009, 9:56pm
Thanks for the reply...
i just like to elaborate my problem....
As you know the BGR has two stable operating points: One in which no current is flowing through the circuit which is the unwanted condition and the second is the desired operation .
To avoid the unwanted operating point we use a startup circuit.
I wanted to simulate the BGR without startup circuit by setting initial conditions to the nodes and see the unwanted condition…(so I did the below sim’s in DC and Tran)
1) I set the initial conditions of the nodes  Vc1 to VDD and V-/V+ to zero, performed the DC simulation and saw all the transistors went  into cut off (i.e which is the undesirable condition)
2) I set the initial conditions of the nodes  Vc1 to VDD and V-/V+ and  VDD ramping (ramp is 15u),performed the tran sim and, I see the BGR is not failing but building up the voltage to 1.2V.
My doubt is why the BGR didn’t fail in the tran sim.am I doing the tran sim correctly?
What I wanted to do next once I see the BGR failing in tran sim, I will connect the startup circuit and I should see the BGR building up the voltage (i.e., the startup is functioning)
Thanks again...
raja.cedt
Reply #4 - May 19th, 2009, 10:16pm
hi,
   in 2nd case you are initializing  nodes  to other than 0 volts,then it will start and same thing happened in your sim also...No doubt your BGR working..connect startup ckt and check..i think it will work.
thanks,
rajasekhar.
somisetty
Reply #5 - May 20th, 2009, 3:11am
its my mistake..
2) I set the initial conditions of the nodes  Vc1 to VDD , V-/V+ to zero and  VDD ramping (ramp is 15u),performed the tran sim and, I see the BGR is not failing but building up the voltage to 1.2V.
raja.cedt
Reply #6 - May 20th, 2009, 4:16am
hi
   i think you are wasting some power in startup unnecessarily,you can remove Ms1,Ms3.
rajasekhar.
somisetty
Reply #7 - May 20th, 2009, 7:28pm
okie...Thanku
i will try removing them and check it...
somisetty
Reply #8 - May 25th, 2009, 9:59pm
hi..
i removed Ms1 and Ms3 and connected the circuit using Ms2.
As i connected only Ms2,the MS2 was in linear and pumping current to V- node in normal operation .So i cascoded the same to disable the Ms2 .I see the startup action happening.But the startup is slow,i mean there is very less difference between the startup time of the BGR with startup and without startup . Pls find the circuit attached...
I read that this kind of architecture degrades PSRR,i am not sure...
The use of startup circuit is to avoid the undesirable operating point in the circuit.Is it that startup circuit also helps in bringing up the bandgap voltage quicker compared to without startup?
raja.cedt
Reply #9 - May 26th, 2009, 12:24am
hi,
   how this startup ckt will effect psrr.Actually the basic property of the startup ckt is it should n't affect its normal operation, moreover settling time of bandgap independent of startup because once a startup ckt introduce disturbance, thats it BGR will take care remaining things(because while starting BGR is +ve feedback ckt so very fast).Why dont you use very simple startup which you can in razaavi?
Rajsekhar.
somisetty
Reply #10 - May 26th, 2009, 2:46am
hi,
Thanks rajsekhar...
i will check in razzavi (for the simple startup circuit)...
Somisetty
raja.cedt
Reply #11 - May 27th, 2009, 12:10am
hi,
   how did you noticed that your startup is effecting settling time?
  and use the attached startup,it wont give any problem.
Rajasekhar.
subgold
Reply #12 - May 27th, 2009, 2:05am
raja.cedt wrote on May 27th, 2009, 12:10am:
hi,
Rajasekhar.
hello raja,
you suggested somisetty to remove two transistors to save power for the normal operation. but doesn't this circuit has the same power wasting problem?
raja.cedt
Reply #13 - May 27th, 2009, 2:33am
no it wont waste power because top pmos has  very small aspect ratio (typically 1/20),or if you have any power budget allocate small fraction of power to startup ckt and you can play with that pmos aspect ratio.
Rajasekhar.
somisetty
Reply #14 - May 27th, 2009, 9:11pm
hi,
Rajasekhar.
Hi Rajasekahar,
i did two types of simulation for seeing the settling time in different corners...
1)Did tran (VDD ramp) without initial conditions for BGR with startup and without startup.
2) Did tran (VDD ramp) with initial conditions for BGR with startup and
without startup.(initial condition Vc1 to VDD)
In 1st case i see the settling time for BGR with startup is late compared to without startup...(the difference is less..but late with startup..)
In the 2nd case i see the settling time for BGR with startup is early compared to without startup...
iam doing the startup u suggested..will let u know the results...
Thanks again
Somisetty
Pages: 1 2
