Jul 18th, 2024, 8:37am
SOI Convergence Problems (Read 2221 times)
emad
Cairo, Egypt
May 24th, 2009, 11:43am
Hello everyone:
I have convergence problems for DC and Tran using SOI devices. Even for a simple circuit like an inverter, it wouldn't converge unless I use trapezoidal and make tolerances really loose. Is this normal? Any ideas on how to improve convergence of SOI circuits?
Re: SOI Convergence Problems
Reply #1 - May 26th, 2009, 5:41am
What models -- BSIMSOI?
I don't expect trapezoidal is helping your DC convergence (unless it's pseudo-tran); I guess I'd be surprised if changing the tolerances makes DC work better, either -- once you're close, Newton's method should work quite well to reduce the error, unless there's some error in the derivatives of the model (and if you're far away so Newton isn't quadratically converging, then increasing tolerances isn't likely to help).
