lily wrote on May 21st, 2009, 11:16am:I am trying to get the time domain steady state solution from the pss simulation for VCO.
Is there any way that I can control the time points in the solution, say I want to get more time points than default solution.
What EDA vendor's simulator do you mean as "pss" ?
There are many simulators which have analysis called as PSS.
If you mean PSS analysis of Cadence Spectre, set "maxstep" parameter for PSS statement.
Enter "spectre -h pss" in Unix command line, you can see many parameters for PSS.
