Jul 2nd, 2025, 8:23am
simvsion problem (Read 5511 times)
godfather
simvsion problem
Aug 13th, 2009, 10:53am
hello all,
I am getting weird problem using ams simulator version is 08.20-p003.
please have a look at attachment. the example i used is from this website ch4 listing 18. actually i tried all examples but same error.
system is ubuntu 9.04 dvd 32 bit powered.
thx
godfather
Re: simvsion problem
Reply #1 - Aug 13th, 2009, 11:10pm
simulator design terminated abnormally....???,
answer:
none of the ports of the server were open. so administrator opened that port required to run that piece of software and now its working fine.
thx
« Last Edit: Aug 14th, 2009, 1:15pm by godfather »
Forum Administrator
YaBB Administrator
Reply #2 - Aug 13th, 2009, 11:49pm
In general you should make sure the important part of your question is in text rather than in a graphic. That way other people having the same problem can find your post using a search engine.
And once you have asked a question, you really should post the answer once you find it. You should assume that if you are having the problem, others will as well.
By asking a question, you are hoping that others will help you. As such, you should also be willing to help others.
