I did something similar years (16 years?) ago with SaberVerilog and using GPIB to control some measurement equipment. In my case it wasn't with feedback from the actual measured chips - I was primarily doing it to control the test equipment to get the design into a test state and then measure some of the internal blocks.
So it can be done. I must admit I've forgotten how I did it. It may have been PLI-based (probably not VPI, because it pre-dates VPI), if my memory is correct.
