Sep 26th, 2024, 4:40pm
need charge pump circuit for negative voltage generator (Read 2838 times)
trashbox
Nov 26th, 2009, 7:25pm
I need use a charge pump to generate a negative voltage, the attachment is a classical circuit, however the efficiency is not very good because the large switch (MP0,MN1,MN2 and MN3) have large current.
Is there any other charge pump circuit with good efficiency to generate negative voltage? Thanks in advance.
Best regards,
Trashbox
