Jul 16th, 2024, 11:27am
True Sphi Plot in Cadence ? (Read 9758 times)
Mayank
Dec 11th, 2009, 12:59am
    I am doing a phase noise analysis in cadence [ IC6.1.3 ] spectre [ MMSIM7.1 ]
LΦ plots are inaccurate below the linewidth as it shows more than 0dBc/Hz phase noise which is irrelevant.
 I want to obtain a true SΦ plot in cadence...How can i obtain that ??
As Pancho pointed out earlier in one of his posts, http://www.designers-guide.org/Forum/YaBB.pl?num=1244213153/6#6 & i quote Quote:
For noisetype="jitter" or "modulated",
you can get  LLSB(f), LUSB(f), AM noise, PM noise in "pnoise modulated of Direct Plot Form",
and also you can get Phase Noise in "pnoise jitter of Direct Plot Form" as true SΦ(f).
When i simulate both pnoise sources and pnoise modulated, I get the same plots for both i.e. Phase Noise in pnoise option in sources analysis & Phase Noise in pnoise Jitter option in modulated pnoise analysis.
  This is not in accordance with pancho's statement in the above mentioned quote...I am confused again.
Can anyone tell me how to get the True SΦ plot in cadence ?
regards,
Mayank.
Re: True Sphi Plot in Cadence ?
Reply #1 - Dec 11th, 2009, 1:32am
Mayank wrote on Dec 11th, 2009, 12:59am:
I want to obtain a true plot in cadence...How can i obtain that ??
Using noisetype= "modulated" or "jitter", you can get SΦ(f).
    - You can get SΦ(f) as "2*PM noise" in "pnoise modulated of Direct Plot Form".
    - You can get SΦ(f) as "1*Phase Noise" in "pnoise jitter of Direct Plot Form".
« Last Edit: Dec 11th, 2009, 4:56am by pancho_hideboo »
Mayank
Reply #2 - Dec 11th, 2009, 1:38am
hi Pancho,
              That's what you indicated in one of your earlier posts also....But when i simulate it, both pnoise jitter & LLSB from pnoise modulated options give same phase noise plots -- exactly equal...
Also, Is there a way to convert Output Noise SV(f) into true SΦ(f) -- I could try this if you could suggest me how ??
Also, what is the correspondence between the units dBrad/Hz  &  dBc/Hz ?? -- As in i mean, if i know that phase noise of -40dBc/Hz @ 10kHz offset, how do i know it's equivalent in SΦ(f) ??
thanx,
mayank.
Reply #3 - Dec 11th, 2009, 1:42am
I think you should post your questions in http://www.cadence.com/Community/forums/33.aspx not in this forum.
Mayank wrote on Dec 11th, 2009, 1:38am:
My simulation result is :
Phase Noise in "pnoise=jitter of Direct Plot Form" is
about 3dB larger value than LUSB(f) of "pnoise=sources".
I don't know why your results of them are completely same.
Your results in http://www.designers-guide.org/Forum/YaBB.pl?num=1050465395/17#17 are coincident with my results.
LUSB(f) is normalized SV(f) conceptually.
But LUSB(f) of "pnoise=sources" is not true normalized SV(f).
I don't think I can get true normalized SV(f) by using Cadence Spectre.
-37dBrad/Hz@10kHz.
« Last Edit: Dec 11th, 2009, 7:00am by pancho_hideboo »
Mayank
Reply #4 - Dec 11th, 2009, 2:14am
Hi Pancho,
                 I will check my simulation once again for pnoise jitter & pnoise sources....
As for true Sphi, are there any other simulators like Agilent ADS / GoldenGate / synopsis XA / eldo / bdasim - which can provide true Sphi instead of LSSB/LUSB/LLSB ?? I can try some other simulator.
regards,
mayank.
Reply #5 - Dec 11th, 2009, 2:18am
Mayank wrote on Dec 11th, 2009, 2:14am:
Using noisetype= "modulated" or "jitter" in Cadence Spectre Pnoise, you can get nearly true SΦ(f).
As far as we use small signal noise analysis in frequency domain, we can never get true result.
This is true for any vendor's simulators.
http://www.designers-guide.org/Forum/YaBB.pl?num=1259714206/2#2
« Last Edit: Dec 11th, 2009, 5:45am by pancho_hideboo »
