Aug 17th, 2024, 1:12am
phase noise simulation in driven circuit (Read 4164 times)
yc
Dec 23rd, 2009, 9:55am
Dear All,
Anybody has an idea using Spectre to simulate phase noise for driven circuits (CMOS logic circuit or differential buffers)? PNoise(source type) is applicable for automomous circuits I think. Anyone has other procedure for those driven circuit? Thanks a lot.
Re: phase noise simulation in driven circuit
Reply #1 - Dec 24th, 2009, 1:26am
Any vendor's small signal noise analysis subjected to master large signal steady state analysis is applicable for both driven and autonomous circuits without any confusion.
Of course, you can adopt pnoise analysis of Cadence Spectre for driven circuit with almost same setting for autonomous circuits.
See the followings.
http://www.designers-guide.org/Forum/YaBB.pl?num=1207830622
http://www.designers-guide.org/Forum/YaBB.pl?num=1208866022
http://www.designers-guide.org/Forum/YaBB.pl?num=1215056515
http://www.designers-guide.org/Forum/YaBB.pl?num=1239205157
yc
Reply #2 - Dec 25th, 2009, 12:24am
thanks a lot!
Mayank
Reply #3 - Dec 25th, 2009, 7:11am
     Pnoise - time domain is pnoise analysis for driven circuits. Also refer to Ken's paper on Pnoise+Jitter. There he explains it beautifully.
Mayank.
Reply #4 - Jan 3rd, 2010, 12:39pm
Mayank,
You don't have to use the timedomain option for pnoise if the circuit is driven. It entirely depends on what you're trying to measure!
