Jul 17th, 2024, 12:32pm
Verilog A model for white noise source (Read 11095 times)
Mayank
Jan 24th, 2010, 10:30pm
    I am new to verilogA but am trying to write a verilogA model for white noise source...It isn't compiling...
My Code :---
`include "constants.vams"
`include "disciplines.vams"
module white_noise_source(p, n);
inout p;
inout n;
electrical p;
electrical n;
parameter real T = 200;
parameter real R = 10e3;
parameter real k = 1.38e-23;
V(p,n) <+ white_noise(4*'P_K*T*R,"thermal");
The Compilation error is :--
Error found by spectre during AHDL compile.
   ERROR (VACOMP-2259): "V<<--? (p,n) <+ white_noise(4*'P_K*T*R,"thermal");"
       "/work/rf/white_noise_source/veriloga/veriloga.va", line
       16: syntax error.
   ERROR (VACOMP-1814): Maximum allowable errors exceeded. Exiting AHDL
       compilation....
Could somebody pls explain this / correct this error ?? Or if somebody has already built a white noise source model...could you post it pls. ??
mayank.
Re: Verilog A model for white noise source
Reply #1 - Jan 24th, 2010, 10:37pm
Mayank wrote on Jan 24th, 2010, 10:30pm:
Simply there is a typo.
It has to be :
    V(p, n) <+ white_noise(4*`P_K*T*R, "thermal");
« Last Edit: Jan 25th, 2010, 1:16am by pancho_hideboo »
Reply #2 - Jan 25th, 2010, 6:49am
Pancho is right about the ' vs `
However, it looks to me that the compiler is actually complaining before that point, perhaps because there is no "analog" before the contribution.
analog
or
analog begin
(you'll need begin/end if you have more than one statement in the analog block)
