Jul 18th, 2024, 1:14pm
pstb gives strange results (Read 9720 times)
aaron_do
Feb 02nd, 2010, 12:59am
i'm trying to run a stability analysis on a current output passive mixer which is essentially a passive mixer followed by a trans-impedance amplifier. I first tried modelling the output impedance of the switching stage (the passive mixer) as a resistance, and then ran the normal stability analysis to find the loop gain. Here i found no problems. I used a cmdmprobe to break the loop. However, when I ran the pstb analysis with the LO signal turned on, the DC loop gain dropped from 70 dB down to -30 dB. Has anybody else encountered a problem like this? The PSS and Pnoise analysis give reasonable results.
thanks,
Aaron
Re: pstb gives strange results
Reply #1 - Feb 2nd, 2010, 1:36am
aaron_do wrote on Feb 2nd, 2010, 12:59am:
PSTB is no more than PAC of sideband=0.
Where do you insert probe ?
See http://www.designers-guide.org/Forum/YaBB.pl?num=1217939784/3#3
BTW, I don't use Cadence Spectre for RF circuits design.
I use interstage impedance probe or custom loop gain probe with master steady state large signal analysis for stability analysis.
Again see http://www.designers-guide.org/Forum/YaBB.pl?num=1240334878/10#10
« Last Edit: Feb 2nd, 2010, 2:53am by pancho_hideboo »
aaron_do
Reply #2 - Feb 2nd, 2010, 7:51am
thanks for the reply.
I'll try PAC tomorrow. thanks
I'm using an op-amp based TIA, so I inserted the probe at the input of the opamp (connected to the gate of the input transistor).
I expected there to be some difference between stb and pstb analysis, but obviously not that much. BTW in order for PAC analysis to run correctly, I had to change the parameter "version" in the BSIM model file from "version=3.3" to "version=3.2". Could the problem have something to do with that?
thanks,
Aaron
Reply #3 - Feb 2nd, 2010, 11:06am
I doubt that the version of the model would make a difference, but it does suggest that maybe you are using a rather old version of MMSIM. What version of spectre are you using? (this should appear in the output log file).
aaron_do
Reply #4 - Feb 2nd, 2010, 7:42pm
Hi Andrew,
the log file says i'm using version 6.2.1.145  from Jan 10, 2008. I'll see if I can update it...
thanks,
Aaron
Reply #5 - Feb 2nd, 2010, 10:24pm
Not that I'm sure this will fix it - but it's worth trying a newer version anyway, just in case.
aaron_do
Reply #6 - Feb 2nd, 2010, 11:24pm
ok it seems that i wasn't using the model with version=3.2, but the one with version=3.3. Now that i've changed it to version=3.2 it works. I guess i'll try updating the spectre version later when i have more time.
thanks,
Aaron
Frank Wiedmann
Munich, Germany
Reply #7 - Feb 3rd, 2010, 12:48am
This is in fact a known problem. Please see Cadence solution 11487974 (it talks about PAC but other periodic small-signal analyses like PXF and PSTB were probably affected as well). The problem was fixed by CCR 588933 in MMSIM versions 6.2.1.345 and 7.0.1.076.
aaron_do
Reply #8 - Feb 3rd, 2010, 6:52am
Thanks a lot! I guess i'll see if I can update MMSIM sooner than I thought,
thanks,
Aaron
Reply #9 - Feb 3rd, 2010, 12:09pm
I feel a little embarrassed now! Thanks Frank for finding something that as a Cadence AE I really should have found (my lame excuse is that I didn't actually look, and I don't actually remember the issue from 2 years ago).
