Jul 2nd, 2025, 5:36am
counter (Read 5338 times)
manikandan
counter
Feb 13th, 2010, 4:56am
hi..
i want to divide the input frequency by 40..am using a 6 bit counter that resets at 101000(40)..i.e when d3 and d5 are 1 then counter nust reset..
am new to verilog a and cadence..i didnt get the output wave which should actually remain high for 40 input clocks..help pls..
include "constants.vams"
include "disciplines.vams"
module bitcounter(clkout,clk,reset);
output clkout;
electrical clkout;M
input clk;
electrical clk;
input reset;
electrical reset;
parameter real vlogic_high=3.3;
parameter real vlogic_low=0;
parameter real vtrans_clk=1.65;
parameter real vtrans_reset=1.65;
parameter real tdel=60p;
parameter real trise=100p;
parameter real tfall=100p;
integer reset_flag;
integer count;
integer d[0:5];
integer i;
analog begin
@ (cross(v(clk)-vtrans_clk, +1)) begin
if(v(reset) < vtrans_reset) begin
if (d[3]&&d[5]) begin // is this correct?
reset_flag = 1;
count=0;
else
reset_flag=0;
for(i=0;i<=5;i=i+1) begin
count=count+1;
v(clkout) <+ transition (vlogic_high*d[5]*d[3]*!reset_flag, tdel, trise, tfall);
//is this a correct approach?
Re: counter
Reply #1 - Feb 14th, 2010, 9:56am
manikandan wrote on Feb 13th, 2010, 4:56am:
What do you mean by "cadence" ?
The followings are general notes for you.
- Always describe vendor's name which you use as tool or simulator.
- Don't do multiple posts which are same content.
- Don't request source code or behavioral model without any efforts.
- There are many simulators which have analyses called as PSS, PAC and Pnoise.
- Describe in detail with using correct terminologies.
- Warnigns are different from Errors.
- ADS is not name of simulator.
- There is no tool which name is Cadence.
- Don't use Direct Plot of Cadence ADE blindly without knowing definition.
- All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
- Don't mix up Simulation with Post Processing. They are completely different phase.
- MATLAB are different from Simulink.
- Learn measurements using actual instruments. Not "EDA Tool Play
I can't understand what you mean by "actually remain high for 40 input clocks".
If output wave is high during 40 input clocks, divide ratio is 80 not 40.
And before arguing output wave, there are syntax errors and many incompletenessed in your Verilog-A code.
Do you truely run this Verilog-A code.
output clkout;
electrical clkout;M
input clk;
electrical clk;
input reset;
electrical reset;
integer reset_flag;
integer count;
integer d[0:5];
integer i;
analog begin
reset_flag = 1;
count=0;
else
reset_flag=0;
count=count+1;
Do you think so?
First, there is no definition for d[3] and d[5]. How do you define "d[0:5]" ?
Remake verilog-A code after studying the following.
http://www.designers-guide.org/VerilogAMS/functional-blocks/freq-divider/freq-di...
« Last Edit: Feb 15th, 2010, 6:47am by pancho_hideboo »
Re: counter
Reply #2 - Feb 15th, 2010, 11:32am
I guess Pancho didn't see the declaration
integer d[0:5];
but I don't see any assignment to d, only using the values.
Re: counter
Reply #3 - Feb 15th, 2010, 2:46pm
Geoffrey_Coram wrote on Feb 15th, 2010, 11:32am:
integer d[0:5];
I mean this. And I know there is "integer d[0:5];".
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: counter
Reply #4 - Mar 4th, 2010, 6:21am
I guess that d[3] && d[5] tries to check whether the bits 3 and 5 of integer d are set. That is not the way to code this in Verilog-A. This is not digital hardware, not even RTL. The simple check should probably be:
if (count >= 40)
When starting from scratch with a model it is best to write the model in plain code, and not try to do some optimizations. Once the model works you can still apply these optimizations, the first target should be a working model. This applies to any model and any language!
Cheers,
Marq
Re: counter
Reply #5 - Mar 4th, 2010, 6:33am
Marq Kole wrote on Mar 4th, 2010, 6:21am:
Problem is there is no assignment for d[5:0] in code.
Even if this code is Verilog-D or Verilog-AMS, there is no counting description for d[5:0].
To make this code workable as Verilog-A, count number should be mapped to d[5:0] for example.
However see the following. He abandoned to use d[5:0].
http://www.designers-guide.org/Forum/YaBB.pl?num=1266353533/2#2
