Jan 11th, 2025, 10:22pm
MosCap (Read 16789 times)
GaAs_si
sandy
MosCap
Mar 22nd, 2010, 8:26am
HI what is advantages using nmoscap insted of MOSFET
Re: MosCap
Reply #1 - Mar 22nd, 2010, 8:30am
GaAs_si wrote on Mar 22nd, 2010, 8:26am:
I can't understand meaning of your question.
If your design kit have nmoscap for MOS Capacitor, accuracy of modeling as capactor is far good compared to MOSFET.
panditabupesh
Toronto
Re: MosCap
Reply #2 - Mar 26th, 2010, 1:37pm
Look at the capacitance versus gate voltage plot. For nmoscap the gate voltage is closer to zero and that means your C versus V trough is pushed to lower gate voltage.
Bupesh
Re: MosCap
Reply #3 - Mar 26th, 2010, 2:04pm
panditabupesh wrote on Mar 26th, 2010, 1:37pm:
It depends on Vt of MOSFET.
So I don't think CV characteristics of "nmoscap" always shows low Vt MOSCap.
panditabupesh
Toronto
Re: MosCap
Reply #4 - Mar 26th, 2010, 5:52pm
"nmoscap"  is a  term used by most of the foundries for capacitor formed by  a NMOS in NWELL.   And my reply about the CV characteristics  was based on this assumption.
Bupesh
Re: MosCap
Reply #5 - Mar 27th, 2010, 12:14am
panditabupesh wrote on Mar 26th, 2010, 5:52pm:
I don't think so.
Attached is a device structure from "gpdk180_DRM.pdf" of Cadence GPDK180.
Here a term of "nmoscap" is used for "NMOS transistor configured as a capacitor".
Release Date: 2008/09/24
Revision: 3.3
PDK:    gpdk180_v3.3.tar.gz
« Last Edit: Mar 27th, 2010, 6:14am by pancho_hideboo »
Re: MosCap
Reply #6 - Mar 27th, 2010, 12:15am
panditabupesh, maybe you mean structure like attached figure.
But this capacitor is called as "pcdcap" in major foundry.
Sometimes this is also called as nMOS varactor (ncap) and thick oxide nMOS varactor (dgncap).
We can't judge structure from "name".
« Last Edit: Mar 27th, 2010, 2:44am by pancho_hideboo »
oermens
Re: MosCap
Reply #7 - Mar 27th, 2010, 9:46pm
the "major foundry" which uses the name "ncap/dgncap" is for nfet in nwell. i just installed 65nm and 90nm pdks from a different major foundry, they provide nmoscap (nfet in nwell) and moscap_rf. i haven't used the new pdks yet, not sure what the moscap_rf structure is. as far as i've read (in pdk documentation, not generally), they are all standard-vt devices.
Nimrod Ben-Ari
Israel
Re: MosCap
Reply #8 - Apr 21st, 2010, 2:25am
in TSMC and Tower process NMOSCAP refers to Gate oxide over Nwell capacitor, the advantage over PMOS capacitor is that instead of having P+ implants for the Drain/Source and N+ for the bulk you only have N+ implants - thus you reduce the required area, also we saw that the capacitor have slightly better C/Area ratio compared to PMOS with the same gate area, but I never looked for the reason.
Nimrod
Mayank
Re: MosCap
Reply #9 - Apr 21st, 2010, 7:33am
Hi NimRod,
Most Probable reason for this is that NMOSCAP has a thicker gate oxide as compared to NMOS so as to boost its Cap / Area ratio. Just Check.
Both nmosCAP & pmosCAP are non-linear caps whose Impedance varies with the DC voltage on the Gate of the device.
PMOSCAP gives max capacitance near low Voltages & vice versa for NMOSCAP.
on the DC Voltage at the node on which u wanna plug a cap, Use NMOSCAP / PMOSCAP / A combo of both.
Mayank.
Re: MosCap
Reply #10 - May 7th, 2010, 5:11am
Mayank wrote on Apr 21st, 2010, 7:33am:
Hi NimRod,
That doesn't make sense to me.  Thicker oxide would mean lower capacitance (C = εA/d, where d is the distance between the plates).
