Jul 30th, 2024, 5:28am
Driven Right Leg circuit (Read 6466 times)
Victor chan
Dec 28th, 2010, 4:51am
Here is a picture of a part of a circuit, which contains a right leg driver.
My understanding of DRL is a circuit which send a signal to a human body, therefore this human body would have the same 'common voltage' as the circuit, which helps to increase CMRR.
However, I would like to know how the below DRL works, especially at the point A, B and C.
Also I have seen quite a few of DRL circuits, and they all do some sort of filtering (Low pass filter), I would like to know what value of cut off freq is aiming actually.
philcorb
Re: Driven Right Leg circuit
Reply #1 - Feb 18th, 2011, 6:49am
The DRL circuit essentially places the human body within the a common-mode feedback loop, mainly to minimise 50/60Hz main-hum picked up by the body.  The low-pass filtering is for loop stability.
Hope this helps
