Sep 11th, 2024, 2:12pm
Mixed Signal Layout - Seperation of VDDA VDD , GND (Read 2872 times)
AlexPo
Feb 12th, 2011, 12:33am
we design a mixed signal chip with three main parts:
- sensible analog
- switched capacitor based adc
- logic part
all these parts are connected to a the padring, which build up by standard digital output cells, and ESD protected analog cells.
Now my question is - how should we seperate the power lines. I know we have to seperate vdd(digital) and vdda(analog) but what should i do with VDDA of SC Circuits and with the power of padring(digital outbut buffer and esd diode connection)
i want to minimize crosstalk and clockfeedthrough to all analog - and to ensure i high snr for adc.
Second question: Should i separate digital ground and analog grounfd, too? How i can to this becaus LVS notice the connection about substrat and give me an error,
Re: Mixed Signal Layout - Seperation of VDDA VDD , GND
Reply #1 - Feb 13th, 2011, 1:27pm
Lots of fancy routing to keep separated grounds generally leads to a pair of grounds that are DC separated, but solidly tied together at the frequencies of interest due to all the parasitics.
Go to:
http://effectiveelectrons.com/HelpIC.htm
Read the two articles on Noise reduction.
Also look at:
http://effectiveelectrons.com/substrate.htm
Those are a start - let me know if you need more info.
