Jul 28th, 2024, 1:15am
Input referred offset of dynamic latch (Read 35560 times)
Nandish Mehta
Feb 22nd, 2011, 9:29pm
Hello friends,
The latch that I have designed was proposed by Min et al in JSSC Dec 2003 for my application and is shown in the attached figure.
I am interested in simulating its worst case input referred offset under process variation, design corner and under 3-sigma mis-match.
Can any one please suggest me some method to estimate offset under above mentioned condition?
I will be very grateful to you for your inputs. I am very new to latch design and i am designing my first full chip.
Please kindly help.
Nandish
« Last Edit: Feb 22nd, 2011, 11:39pm by Nandish Mehta »
Re: Input referred offset of dynamic latch
Reply #1 - Feb 23rd, 2011, 11:25pm
Please have a look at http://www.designers-guide.org/Analysis/comparator.pdf.
A more simple way is explained below. This is proven to be effective if you have Cadence virtuoso, spectre simulator, and wavescan/VIVA.
  • make a slow ramp input for the comparator,
  • Run monte carlo simulation with mismatch only or process+mismatch.
  • then find the time when the comparator output toggles from 0 to 1, or 1 to 0, depending on the input signal increases or decreases.
  • Measure the input signal at that time.
  • At last the post-processing tool, like Wave Scan or Viva, will plot the histogram of the threshold voltage, with one sigma number. You can made a quick estimation of the max offset voltage with 6 sigma.
Yawei
Nandish Mehta
Reply #2 - Feb 23rd, 2011, 11:48pm
Hi Yawei,
Thank you so much !!! This is exactly what i was looking for. I read through the document you have posted. It is really awesome.
But I find your method more easier as I know how to do it.
Thanks a lot once again !!!
You really save lot of my design time....
Nandish
