Jul 17th, 2024, 11:37am
How to determine the delay in the reset pulse of a PFD ? (Read 6433 times)
harpoon
Hampshire
Aug 15th, 2011, 2:51am
A classic way of avoiding the dead band zone in a standard PFD is to insert a delay in the reset line.
Does anyone know how to determine how long/short this delay should be ?
Thanks.
raja.cedt
Re: How to determine the delay in the reset pulse of a PFD ?
Reply #1 - Aug 15th, 2011, 5:30am
hello,
higher the delay in reset path, will increase the static phase offset. So many people will add enough  delay which can ensure no dead-zone. In many cases this will be done by simulations rather than expressions.
Thanks.
purplewolf
Reply #2 - Aug 15th, 2011, 5:41am
i would like to know how to plot vout vs phase error to see the dead zone in the first place
raja.cedt
Reply #3 - Aug 16th, 2011, 12:37am
hello,
so now i understood your question, you mean to ask how to simulate.
So conect loopfilter cap at the o/p of the charge pump and sweep the phase difference between refclk and fb clk from lag to lead. Then plot the current thorugh the filter cap vs phase difference between refclk and fbclk.
harpoon
Hampshire
Reply #4 - Aug 16th, 2011, 1:25am
opps ... it appears my post has been hijacked and relocated.
@raja.cedt, you understood my question correctly the first time.
My questions is what determines the lower and upper limit of this reset pulse delay ? If the delay is too long, what effect does it have on the PLL ?
Thanks.
raja.cedt
Reply #5 - Aug 16th, 2011, 2:55am
if delay is too long, then both charge pumps turn on for more time, so more ripple on the control voltage hence ref spurs.......
harpoon
Hampshire
Reply #6 - Aug 16th, 2011, 3:58am
so the shorter the better ? i.e. just enough over process, voltage and temp
thanks.
raja.cedt
Reply #7 - Aug 16th, 2011, 5:44am
yes..you are correct. Make sure than you don't have dead zone across PVT.
harpoon
Hampshire
Reply #8 - Aug 16th, 2011, 5:57am
@raja.cedt
thanks for the speedy reply ...
