Sep 21st, 2026, 7:25pm
To change a variable in test bench and pass it to design program (Read 12602 times)
sindhura
Sep 13th, 2011, 12:28pm
Can anyone help me with my problem.
I am  trying to change a parameter in my testbench and pass it to my design module. Basically I am working on processes variations on a device.
I am passing the parameter by using assign statement in my main module. I am trying to compile my program as many times as I change the parameter. But when I try to do change my parameter in always block, my parameter changes parallel with the input voltage. So, I am able to compile it only once. Can someone help me with this?
Thank you,
Sindhura
boe
Re: To change a variable in test bench and pass it to design program
Reply #1 - Sep 15th, 2011, 7:37am
Hi Sindhura,
If you offer more information, you are more likely to get help, e.g.:
Which simulator (and version) do you use, Code/netlist (fragment), ...
B O E
sindhura
Reply #2 - Sep 15th, 2011, 1:44pm
I am using Cadence sim vision 08.20-s014.
I am using verilog AMS for programming.
my test bench is as follows:
module testbench();
 electrical gnd,in;
 ground gnd;
 real index;
real length1;
  m_linear # (.mu(1e-10)) m1(in,gnd);
initial length1 = 50e-9;
always
     begin
     #(2)
     length1 = length1 + 50e-9;
// Create a pulse voltage source as input to the design
       vsource #(.type("pulse"), .val0(1),.val1(-1), .period(20m)) v0(in,gnd);
and in the design module I am implementing
module m_linear(Vp, Vn);
input Vp;
output Vn;
electrical Vp, Vn;
wreal length;// = 50e-9 from (-inf:inf);     //
real Vm;                                           // Terminal voltage
real Im;                                           // Current
parameter real deltaT=1u;//for example.
integer fptr;
assign length = testbench.length1;
analog begin
 Vm = V(Vp, Vn);
 // Calculate the current
 Im=Vm/length;
 I(Vp, Vn) <+ Im;
@(initial_step) begin
fptr =$fopen("/home/sxm7139/Desktop/Memristor/test.txt");
@(timer(1p,deltaT)) begin
$fstrobe(fptr,"%g %g",length,Im);
@(final_step) $fclose(fptr);
sindhura
Reply #3 - Sep 15th, 2011, 1:46pm
In the above program I need to run the design module whenever I change my length, but length and input voltage are varying simultaneously. Can someone please help me with that?
boe
Reply #4 - Sep 16th, 2011, 8:06am
Sindhura,
why do you use wreal for length? I'd expect a real for that.
B O E
Reply #5 - Sep 20th, 2011, 6:20am
sindhura wrote on Sep 15th, 2011, 1:46pm:
Can you present the relation of length and input voltage?
sindhura
Reply #6 - Sep 21st, 2011, 7:08am
Hi Boe,
If I use real I am getting the following error..
Err: A reg is not a legal lvalue in this context
I am using it in continuous assign statement so it can't be a real.
Sindhura
sindhura
Reply #7 - Sep 21st, 2011, 7:10am
I am working on the process variations of a device. I am not supposed to put up the actual device characterstics equation. So I modified the relation. What I need is help with the simulation
Sindhura
boe
Reply #8 - Sep 22nd, 2011, 2:23am
Sindhura,
I expected a real at line Code:
Im=Vm/length;
but didn't think about the assign statement. Perhaps you should convert the wreal to a real?
B O E
boe
Reply #9 - Sep 22nd, 2011, 3:59am
sindhura wrote on Sep 21st, 2011, 7:10am:
Process variation changing over time?
The better we understand your problem, the better the advice we can give you.
B O E
Reply #10 - Sep 23rd, 2011, 9:48am
I still don't understand what you are trying to do.
Why do you have a pulse source, if you don't want the input voltage and length to be changing at the same time?  (Why not a dc source?)
What's the timescale for #(2) -- is it much longer than the 20m period of your pulse source?  (I usually work with Verilog-A, so my digital knowledge is limited.)
How does length change in your real design?  For the example you showed, one could set length in the analog block
 length = (1 + floor($abstime / 2 )) * 50e-9;
(I'm not sure of the units on "2").  Every 2 seconds, length will step up by 50n.  I guess you get 100 periods of your 20ms pulse source this way.
sindhura
Reply #11 - Sep 27th, 2011, 12:20pm
Hi Geoffrey,
I am sorry for not being able to put my question in a proper way.
Lets take the below testbench
module testbench();
electrical gnd,in;
ground gnd;
real index;
real length1;
Whenever I run my design it just simulates the design once with the default L value in the main module. But I want to change my L value so that L lies between : L-5% <L < L+5%
Everytime I change I want to run my simulation.
I can instantiate the modules 10 times in my design with different L values like below.
m_linear # (.mu(1e-10), .length(50e-10) m1(in,gnd);
m_linear # (.mu(1e-10), .length(55e-10) m1(in,gnd);
m_linear # (.mu(1e-10), .length(60e-10) m1(in,gnd);
m_linear # (.mu(1e-10), .length(45e-10) m1(in,gnd);
m_linear # (.mu(1e-10), .length(40e-10) m1(in,gnd);
But it gets too complicated for 100+ variations. So I need someone to help me to do these simulations in an effective way.
Sindhura
Reply #12 - Sep 28th, 2011, 12:38pm
Do you want 100+ instances, each with a different L?
Or do you want 1 instance, but to run a simulation that is 100 times some unit duration, and change L after each unit duration?
Or do you want to call your simulator 100+ times to run the simulation?
sindhura
Reply #13 - Oct 3rd, 2011, 9:11pm
Hi Everyone,
Thank you for help. I came to know that I can generate random numbers for my parameter Length and run the simulations using perl or phython script.
Sindhura
