Sep 4th, 2024, 7:11am
Pls help with measuring current through a pin of a "sub circuit" in hspice (Read 3986 times)
Larry_80
Nov 02nd, 2011, 2:20pm
Hello All, i have a black box/subcircuit, and the outputs are currents, can someone please tell me how to measure the currents of this subcircuit in hspice?? I do not want to use a resistor to sense the current, i am looking for an hspice command that will directly PROBE the current of the sub circuit.
regards
cheshire_cat
Colorado Springs
Re: Pls help with measuring current through a pin of a "sub circuit" in hspice
Reply #1 - Nov 2nd, 2011, 2:31pm
Larry, use the 'isub' command. You may read more about it in the hspice documentation. Basically,
isub(xi1.xi2.portname)
-Chris
