Jul 17th, 2024, 1:43pm
HSPICE .net & .lin (Read 136 times)
newic
HSPICE .net & .lin
Aug 10th, 2011, 12:07am
For the Sparameter analysis, user can use .net & .lin analysis.
What are the differences between them?
spiceoracle
USA
Re: HSPICE .net & .lin
Reply #1 - Nov 2nd, 2011, 9:24am
The .NET analysis is the original HSPICE network analysis command.  .NET is limited to 1 or two terminal networks and cannot output a S-parameter file such as a Touchstone formatted file.
The .LIN analysis is the newer network analysis.  .LIN is much more flexible and easier to use than .NET analysis.  The .LIN analysis can extract network parameters for networks with large numbers of terminals.  S-parameters files in Touchstone format can be output for use in other simulations.
newic
Reply #2 - Nov 2nd, 2011, 5:21pm
thank you Smiley
