Aug 14th, 2024, 10:19pm
Pages: 1 2 3
DRAM DESIGN (Read 23443 times)
chandu28
vellore
DRAM DESIGN
Nov 29th, 2011, 1:28am
Hello guys,
Iam M.S.Chandra Sekhar currently working(mtech-project) in the field of memory design and it is called "Design of 4Kb DDR SDRAM". I am simulating this in Design Architect (Mentor Graphics).For this project I started with DRAM design and I am stuck with it. could anyone please help me out. Actually the problem is with where to connect the refresh circuit. The order  is like this (as I have used)sense amplifier,isolation circuit,cell,refresh circuit,write driver circuit. and I have connected the refresh circuit like a loop to the bitline and by using the pattern Iam running the circuit. The output Iam getting is both distorted and leveled up.
awaiting your reply.... Smiley Smiley Smiley
Re: DRAM DESIGN
Reply #1 - Nov 29th, 2011, 3:56pm
show a schematic please?
chandu28
vellore
Re: DRAM DESIGN
Reply #2 - Nov 29th, 2011, 8:03pm
this is the schematic with complete blocks...can you tell me if all the connections were made correct or not....
thank you Smiley Smiley
Re: DRAM DESIGN
Reply #3 - Nov 30th, 2011, 11:19am
Oh, perfectly connected!
Sad
Very difficult to tell whats what and all that.
Suggest you work on better formulation of the question here, can not really tell what you are doing from that drawing.
AnalogDE
Re: DRAM DESIGN
Reply #4 - Nov 30th, 2011, 4:11pm
Start with a bit-slice and get that working and understood.  After that, then you can figure out how to draw the array schematics.
chandu28
vellore
Re: DRAM DESIGN
Reply #5 - Nov 30th, 2011, 9:17pm
actually this is the schematic of a 1 row DRAM design each block is working individually starting from the top sense amplifier,isolation circuit , cells(row of cells) write driver circuit refresh circuit and at he end column decoder...
we know that the main problem in any design is the connections to various blocks i dunno where the mistake is... thats what is my question sir...
raja.cedt
Re: DRAM DESIGN
Reply #6 - Dec 1st, 2011, 12:04pm
hello chandu,
is your refresh ckt working fine, means is it able to write what it have read from the cell in the given time? refer wste and harris digital design he has pointed out many common mistakes...
Raj.
Re: DRAM DESIGN
Reply #7 - Dec 1st, 2011, 2:23pm
chandu28 wrote on Nov 30th, 2011, 9:17pm:
OK, then suggest you start by using the blocks to build and simulate as you build parts of the schematic until the response is not as expected.
Divide the problem  and understand it  as you go.
Also, if you think there is an unexpected loading effect someplace you may want to either monitor currents in connections, or insert ideal voltage to voltage buffers in lines to determine where the loading problem is.
chandu28
vellore
Re: DRAM DESIGN
Reply #8 - Dec 1st, 2011, 7:19pm
raja.cedt wrote on Dec 1st, 2011, 12:04pm:
hello chandu,
Raj.
hello Raj,
             Yes it is I just gave a random pulse with 1v p-p and vdd to the refresh circuit as 5 v p-p with pattern and I got the result exactly as I expected...
chandu28
vellore
Re: DRAM DESIGN
Reply #9 - Dec 1st, 2011, 7:25pm
loose-electron wrote on Dec 1st, 2011, 2:23pm:
sure sir i get to it right away and since Iam connecting the bit and bitbar lines so close will there be any capacitance effect??? and also can we check sense amplifier individually? because Iam not getting proper swing too....  :) Smiley
Re: DRAM DESIGN
Reply #10 - Dec 2nd, 2011, 12:06pm
If all the individual peieces work as expected -
Isolate the parts using voltage to voltage buffers.
That will teach you if its a loading issue.
chandu28
vellore
Re: DRAM DESIGN
Reply #11 - Dec 2nd, 2011, 10:20pm
loose-electron wrote on Dec 2nd, 2011, 12:06pm:
Sir,
     Can you please be more elaborate???
Re: DRAM DESIGN
Reply #12 - Dec 3rd, 2011, 7:34pm
you have the design of several different pieces in your system.
all of them should have been simulated and designed to work as expected
after that, you have connected them together and something is broken.
Correct so far?
If you use a "voltage to voltage" converter in SPICE/Spectre with G=1 on any and all of the connections between boxes, you should be able to get
the boxes functioning again because now the boxes no longer interact or load each other down.
chandu28
vellore
Re: DRAM DESIGN
Reply #13 - Dec 3rd, 2011, 7:48pm
yes sir you are right...by then I can find the fault location....I will try it sir...
Re: DRAM DESIGN
Reply #14 - Dec 4th, 2011, 12:31pm
not a problem, happy to help,
Jerry
Pages: 1 2 3
