Jul 31st, 2024, 3:17am
PSRR simulation set-up of Bandgap Reference in Cadence (Read 3759 times)
analog_design
INDIA
Apr 10th, 2012, 5:24am
Hi Folks,
I am trying to run PSRR simulation on Bandgap. I have design first order bandgap reference and I am facing difficulty while doing simulation of it.
Please, let me know How should I do set-up of PSRR Simulation in Cadence Spectre .
I would be thankful to you.
Thank you  :)
Warm Regards
View Profile analog_design   IP Logged
Horror Vacui
Dresden, Germany
Re: PSRR simulation set-up of Bandgap Reference in Cadence
Reply #1 - May 25th, 2012, 6:50am
What is your exciting signal (input) in this case?
What is your output signal in this case?
If you know these than it is straightforward to simulate it.
