ywguo wrote on Oct 5th, 2012, 3:32am:Hi analog_design,
1. Probably that is a typo, 8:2 multiplexer.
I am not sure because I don't know the details and background for your scheme.
2. It is not necessary to generate ODD and EVEN signal at the output of serialier. A reasonable structure comes from your requirement, like speed, and the availabe process, and so on.
Yawei
Actually I don't think it is a typo. The internal diagram of the 8:2 serialzer will be the same as the 2-1 that is explicitly shown in the figure. Really what it means to say is it is 2 parallel 4:1 serializers where the ODD path is only nibble and the EVEN path is another.
You only need the ODD and EVEN signals if you are going to use a DDR scheme. Otherwise you only need one data path after the coding block.
